Building a winning Pokemon TCG Pocket Account deck is as much about strategy as it is about the synergy of your chosen cards. While each deck focuses on a unique theme or Pokémon type, some versatile support cards can strengthen any deck. These cards provide consistency, resource management, and the flexibility needed to respond to an opponent moves. Whether you're a seasoned player or a beginner in the Pokémon Trading Card Game Pocket, here’s a comprehensive guide to the best support cards that can fit into any deck.
1. Professor Research
Professor Research is a staple in almost every deck because of its unrivaled draw power. Discarding your hand may seem like a steep price, but drawing seven new cards can turn the tide of any game. This card ensures that your hand never stagnates, giving you access to the resources you need to maintain momentum.
Use it when your hand has few playable cards or when you're in desperate need of a specific resource.
Combine it with cards that have benefits upon being discarded, such as Energy cards or Pokémon with abilities that trigger from the discard pile.
2. Marnie
Marnie disrupts your opponent’s hand while giving you a fresh one. This dual-purpose card is invaluable for disrupting an opponent strategy, especially when they have a large hand full of resources. Simultaneously, it replenishes your hand, providing a consistent flow of cards.
Play Marnie when you suspect your opponent is holding key cards for their next turn.
Combine with cards that let you peek at your opponent hand to maximize disruption.
3. Quick Ball
Quick Ball is an unparalleled search card for basic Pokémon. Since basic Pokémon are crucial for setting up your strategy, this card ensures you can find what you need quickly. The discard requirement can also synergize with other cards that benefit from being in the discard pile.
Use it early to ensure your bench is well-stocked with support or attacker Pokémon.
Pair with Professor Research for a seamless draw-discard-search combo.
4. Boss Orders
Boss Orders is the ultimate disruption card, allowing you to target and bring any Pokémon from your opponent bench into the active position. This ability can swing the game in your favor by eliminating key threats before they become a problem.
Save it for critical moments when you can knock out a high-value Pokémon.
Use it strategically to force an opponent support Pokémon, like Crobat V, into the active position for an easy knockout.
5. Switch
Switch is a simple yet invaluable card that allows you to switch your Active Pokémon with one on your Bench. It bypasses energy retreat costs and provides flexibility in navigating tricky situations.
Combine with Pokémon that have high retreat costs to ensure mobility.
Use it defensively to avoid knockouts or offensively to bring a fully powered Pokémon into play.
6. Evolution Incense
Evolution Incense is crucial for decks that rely on evolving Pokémon. It allows you to search your deck for any Evolution Pokémon, ensuring a smooth progression of your strategy.
Use it as soon as your basic Pokémon are ready to evolve.
Pair with cards that let you shuffle your deck afterward, like Pokégear 3.0, to prevent your opponent from knowing your remaining cards.
7. Ordinary Rod
Ordinary Rod provides excellent recovery options, allowing you to shuffle Energy and Pokémon cards from your discard pile back into your deck. This card is vital for maintaining resources during long games or after losing critical Pokémon.
Use it after losing an important Pokémon in battle.
Combine with search cards like Quick Ball to immediately retrieve shuffled Pokémon.
8. Energy Recycler
Energy Recycler is a lifesaver for decks that burn through Energy quickly. It allows you to shuffle up to five Energy cards back into your deck, ensuring you don’t run out of resources.
Use it mid to late game when you’ve exhausted a significant amount of Energy.
Combine with cards that help you search for Energy, like Energy Search, to accelerate energy attachment.
9. Air Balloon
Air Balloon reduces the retreat cost of the Pokémon it’s attached to by two Energy. This Tool card is a versatile option for improving mobility across all deck types, especially those with heavy retreat costs.
Attach it to support Pokémon to easily rotate them out of the active position.
Use alongside Switch for even more maneuverability.
Support cards are the backbone of any successful Pokémon TCG Pocket deck. While attackers and strategies may vary, cards like Professor Research, Marnie, and Quick Ball ensure that your deck remains consistent and adaptable. Including these versatile cards not only strengthens your deck but also prepares you for a wide range of opponents and scenarios.
Experiment with these cards, tweak your deck to fit your playstyle, and buy Pokemon Account remember that the best decks are built on a foundation of strong support.
