Architect architecte Ian Farrier /new zealand
Length Overall (LOA) longueur ht 13,75 m
Beam Overall (BOA) largeur 7,15 m
Hull Draft mini keels tirant d`eau 1,35 m
Mast high above water Mât haut sur l'eau 20,50 m
displacement poids lêge 9,5 t
Mainsail grand-voile 62 m2
Genua voile d avant 33.5 m2
Freshwater tanks` Reservoirs eau douce 2 x 400 l
Diesel tank Reservoirs carburant 2 x 200 l
Engines YANMAR marque 2 x 29 HP
Saildrive Yanmar SD20 ,3 blade folding propeller
Black water tank cuve de rétension 80l
Refregirator Freezer
Sailing area acc.: cat.d`armement Certification Cat. A
PAINTING Hull: couleur pont Gelcoat White RAL 9010.
INTERIOR LAYOUT
Owner standard konfiguration: amenagements
2 x double beds nombre de cabines 3 1 single bed couchettes 2 el. toilets . 2 el. toilettes . 2 sinks+ showers 1 shower on deck
GALLEY
Standard L-shaped galley with wood countertop.
Large stainless sink with quality fixtures, hot/cold running water and side draining surface.
Large storage under the countertop and below the sink.
Flush mounted gas stove with ceramic plate and separate microwave oven.
U shaped couch with large table
wine glass shelves
3 x 230V AC electrical socket.
All furniture is made with: • SUPERLIGHT wood-foam-wood panels
LED lighting.
NAVIGATION STATION
Portside large chart table with a complete panoramic view.
Ergonomic console for navigation and communication instruments.
Console with 1 x 230V AC and USB electrical sockets.12V DC socket
White/Red LED adjustable lamp.
Furuno plotter, VHF handheld and VHF build in
PORTSIDE OWNER’S HULL; AFT CABIN
door for closing the cabin for total privacy., Queen size bed: length 2.00 m, width 1.60 m, 12 cm high comfort mattress
Lateral step for easy access to the bed., Inboard books shelf., Settee next to bed with internal storage.
LED reading lamps at head of the bed., Windows to the hull side. (is to open )
HALLWAY/MIDSHIP
Inboard spacious multiple wardrobe lockers, windows to the hull side.
Fixed tempered glass escape hatch (570 x 500 mm) under stairs to the internal hull side.
BATHROOM
Spacious inboard wooden counter with cupboard storage below., sink basin and stainless tap with hot/cold running water.
1 x 230V AC electrical socket.
FRONT CABIN TOILET
Inboard electrical toilet. TECMA silence, separate shower
STARBOARD GUEST’S HULL AFT CABIN
door for closing the cabin for total privacy., Bed: length 2.00 m, width 1.60 m, 12 cm high, comfort mattress, Lateral step for easy access to the bed. Inboard books shelf., Outboard wardrobe (closet and drawers)., LED reading lamps at head of the bed.
HALLWAY
Access via door to cabins and central bathroom., Fixed escape glass hatch (570 x 500 mm) under stairs to the internal hull side.
CENTRAL GUEST BATHROOM
Outboard counter with large cupboard storage below., basin and stainless tap with hot/cold running water. Wall mirror above counter, fixed on cupboard with double storage.
FRONT CABIN
Electrical toilet. TECMA silence, separate shower.
DECK LAYOUT & RIGGING
Anodized Aluminium mast. AISI 316 Stainless Steel 1 x 19 wires standing rigging., Anodized Aluminium boom with internal single line reefings, with 3 reefs, Padeyes for lazy jack., 1 x Windex on mast head.
Regulatory navigation lights (port, starboard, stern, masthead, mooring).
Composite Forward Crossbeam and compression beam/bowsprit with built-in Primary Anchor Roller. Extra line roller for boje maneuvre.
RUNNING RIGGING & DECK GEAR
1 x 50.2 Harken electrical winch inside cockpit( mainsheets mainsail, tender lift, Spinnaker) .
1 x 42.2 Harken electrical genua winche, 1x Harken winch for furlex, 2 x 50.2 Antal inboard winches (, gennaker and Code 0 sheets).
Rope clutches for control lines on deck and mast.
ANCHORING & MOORING
7 x 320 mm stainless steel cleats, 14 x stainless steel stanchions 61 cm high, Double synthetic Lifelines, Horizontal 1500W electrical anchor windlass
Stainless steel Delta anchor 25 kg, 50m long galvanized 10 mm chain and 50m braided nylon rope.,Second anchor Danforth
High comfort white Trampoline, individually attached to hulls, bowsprint and transversal beam., Composite davits build for tender lifting and solar panels
COCKPIT
Portside L-shaped seating area with storage and composite table, Starboard seating area with ample storage., seats on aft crossbeam with storage below. LED lights, 2 Solar panels on composite davits with 2x450Wh peak.
HELM STATION & STEERING
fixed wheel helm stations with back rests, composite consoles, stainless steel, fixed wheels.
2 x composite balanced rudders on self-aligning non-metallic PETP bearings with AISI 630 shaft 55 mm of diameter.
Hydraulic steering System.
TECHNICAL EQUIPMENT
2 x 29 HP YANMAR diesel engines
2 x YANMAR SD 20 Saildrive trasmission
2 x 3-blade folding propellers for minimum drag
2 x 200 l Alu diesel tank
2x double fuel filters per motor
1 x mechanical engines controls on starboard helm station
2 x blower fan for engine room ventilation
Complete damping and noise insulation in each engine room compartment
WATER SYSTEM
2 × 400 water tanks with independent circuits (hot/cold), 2 x 12V pressure pumps, Each waterpump system with separate filter systems
60 l water heaters with 230V heating elements, 80 l high grade linear polythene self-emptying black water tanks
ELECTRICAL SYSTEM
12V / 24V DC and 230V AC/50Hz or 110V AC/60Hz voltage circuits, Victronic Charger for service batteries.
Sterling power distribution for loading motor, service and navigation batteries
2 x engines starting batteries AGM 60 Ah 12V, 3 x services AGM deep cycle batteries, 2 x alternators 125A/12V for engine batteries.
1 x 230V Shore power outlet with 25 m of extension cord Electric control panel with thermal circuit breakers. Outlets: 230V/110V AC, 12V DC
LED illumination
NAVIGATION ELECTRONICS FURUNO
Furuno wind/depth/log system, autopilot, FURUNO DRS4W Radar, 2x VHF marine radio standard Horizon, Navigation FURUNO NavNet TZT touch3 15”
SAFETY EUIPMENT
EPIRB, Man over bord boje, Life raft for 6 persons, 6 life jackets, Bilge pumps, Boarding ladder integrated in transom, 2 escape hatches
Gaz detector, 3 fire extinguisher
1 x 50.2 Harken electrical winch inside cockpit( mainsheets mainsail, tender lift, Spinnaker) 1 x 42.2 Harken electrical genua winche
1x Harken winch for furlex, 2 x 50.2 Antal inboard winches (, gennaker and Code 0 sheets).,Rope clutches for control lines on deck and mast.
7 x 320 mm stainless steel cleats., 14 x stainless steel stanchions 61 cm high, Double synthetic Lifelines, Horizontal 1500W electrical anchor windlass, Stainless steel Delta anchor 25 kg, 50m long galvanized 10 mm chain and 50m braided nylon rope. Second anchor Danforth
High comfort white Trampoline, individually attached to hulls, bowsprint and transversal beam Composite davits build for tender lifting and solar panels
Portside L-shaped seating area with storage and composite table. Starboard seating area with ample storage seats on aft crossbeam with storage below. LED lights, 2 Solar panels on composite davits with 2x450Wh peak
Outlets: 230V/110V AC, 12V DC, LED illumination
EPIRB ,Man over bord boje, Life raft for 6 persons, 6 life jackets, Bilge pumps, Boarding ladder integrated in transom, 2 escape hatches, Gaz detector 3 fire extinguisher
1 x 50.2 Harken electrical winch inside cockpit( mainsheets mainsail, tender lift, Spinnaker) , 1 x 42.2 Harken electrical genua winche
1x Harken winch for furlex, 2 x 50.2 Antal inboard winches (, gennaker and Code 0 sheets). Rope clutches for control lines on deck and mast.
7 x 320 mm stainless steel cleats., 14 x stainless steel stanchions 61 cm high, Double synthetic Lifelines,Horizontal 1500W electrical anchor windlass , Stainless steel Delta anchor 25 kg, 50m long galvanized 10 mm chain and 50m braided nylon rope., Second anchor Danforth
Portside L-shaped seating area with storage and composite table. Starboard seating area with ample storage., seats on aft crossbeam with storage below. ,LED lights, 2 Solar panels on composite davits with 2x450Wh peak.
fixed wheel helm stations with back rests, composite consoles, stainless steel, fixed wheels. 2 x composite balanced rudders on self-aligning non-metallic PETP bearings with AISI 630 shaft 55 mm of diameter.
Victronic Charger for service batteries. Sterling power distribution for loading motor, service and navigation batteries
Outlets: 230V/110V AC, 12V DC ,LED illumination
