letzter Beitrag 23.09.18 um 23:43 von  alaussa
Malö 106 - 35' - für Langfahrt ausgestattet / KARIBIK - Grenada / 52.000€
alaussa
07.06.18 um 23:48
    Die 1983 erbaute 35-Fuss Segelyacht der schwedischen Werft Malö besticht durch ihr
    geschütztes Center-Cockpit und ihre geräumige Achterkajüte
    Dieser gemässigte Langkieler ist perfekt für die Langfahrt ausgestattet und ist abzugeben,
    mit allem, was man benötigt – alles von Geschirr über Ersatzteile bis hin zur grossen
    Bordapotheke.
    Derzeit wird das Boot in der Ost-karibik gesegelt und befindet sich in Grenada. Der Übergabe-Termin und –Ort sind flexibel.
    Masse:
    Länge über alles: 10,60 m
    Breite: 3,27 m
    Tiefgang: 1,58 m
    -8 minutes video, interior and exterior:https://youtu.be/NYv4xZkxkHE
    This Malö 106 exemplar is a true bluewater boat, prepared to be single handed and also very comfortable for living at anchor with lots of room and good internal division. The center cockpit is very spacious and offers a safe and comfortable feeling underway, also very dry due the hard dodger.
    The boat is very well maintained and in great shape for her age and shows well. Her current owner lived aboard for the last 2.5 years and took great care and did several upgrades and improvements. It is in turn key condition with great cruising gear, ready to go anywhere.
    The interior is is in a very good condition has a warm and nautical atmosphere. There are two spacious double cabins, a comfortable saloon, galley and wet cell. Through the whole ship there is generous amounts of stowage both over and under the berths. The deck layout is practical, all decks are wide and provide a safe and easy passage.
    *Owner's statement*
    I wanted a seaworthy, comfortable and solid boat that I would be able to singlehand. I am very satisfied and this boat brought me immense satisfaction. I particularly appreciated the comfortable way the boat sail in bigger seas. The aft cabin is spacious and cozy for long navigations. A little heartbroken we will part ways since I’m seeking new challenges on land. I am willing to spend a couple days aboard to share with the new owner the handling of all systems, my cruising knowledge or to help sail the boat to a different location than it currently is.
    Equipment:
    •Motor
    Volvo Penta 39 HP (new 2009, 1900h)
    The engine room is accessible from the front and from the top and the front
    •Sails
    Full batten main sail from Haase Segel (3 Reefing points)
    Furling headsail 110% UK Halsey (2012) new UV Cover (2014)
    Furling headsail II (old but in good condition)
    Spinnaker with sleeve (old but in good condition)
    Spinnaker pole
    Boom brake Walder
    New running rig 2014
    •Autopilot
    Electronic wheel autopilot Autohelm 4000
    Windgear windwane self-steering(new 2014)
    •Navigation
    GPS plotter Raymarine C120
    Various paper maps (esp. North Atlantic, Caribbean, US East Coast)
    AIS transceiver EasyTRX 2S IS-IGPS
    VHF radio with AIS display Standard Horizon GX2000
    Sensors and display for depth sounder, wind speed and direction
    •Anchor
    Rocna 20kg (new 2016)
    Original Bruce anchor 15 kg
    Fortress FX-23 anchor
    Stock anchor (folding) 15 kg
    210 feet (64 meters) chain 8 mm (new 2016)
    130 feet (40 meters) anchor line
    Additional anchor line and 150 feet (30 meters) chain 8mm
    Electric anchor windlass Panther Lofrans 1000W (engine overhauled 2018)
    Mantus anchor hook with bridle (new 2016)
    •Electricity
    House battery 210 Ah (2x105 Ah lead-acid, new 2016)
    Engine Battery 65 Ah (SMF lead-acid, new Sep 2017)
    Wind generator ( 300 W, new 2014)
    Solar panel ( 100 W, new 2014)
    Solar Panel Controller MPPT Victron 30-100 with Bluetooth (new Nov 2017)
    Battery Monitor Nasa BM-2
    220 V / 50 Hz shore power connection
    Charger ProMariner - ProNautic 12-40P (new Oct 2015 - never used)
    2 inverters 200 watts (220V)
    1 inverter 300 watts (110V)
    •Safety
    EPIRB (new 2014)
    SPOT tracker (new 2016)
    Handheld VHF (2x)
    6 automatic vests, 2 of them with AIS-SART
    3 lifebelts
    3 fire extinguishers
    Liferaft SeaSava Plus R 6 persons (maintenance due on Jan 2019)
    Emergency tiller
    Radar reflector
    Miscellaneous Offshore Pyromaterials (2014)
    Handheld GPS Magellan Triton
    Big on-board set of medicine and first aid kit (new 2014)
    Emergency Bilge pump Rule Evacuator 4000 with hose (new 2016 never used)
    Spotlight Stanley Fatmax SL10Leds (new 2016)
    Shortwave receiver with SSB Tecsun - PL660 (new 2016)
    Binoculars Minox 7 x 50
    •Galley
    2-burner gas cooker (semi-cardan) with oven (new 2013)
    Hot water: 5 gallons (20 liters) boiler. Heat by shore power or when the engine runs
    Two gas bottles (11, 6 kg) various adapters for filling in different countries
    Fridge / Freezer Angel MR040F (new Nov 2017)
    Electric pump (new 2017) for fresh water (with activated carbon filter)
    Foot pump for salt water on the galley sink
    Various pots, cutlery, dishes, measuring cup, blender
    •Wet cell
    Jabsco manual toilet (new Jul 2017)
    Hot and cold water pressurized shower head
    •General
    Water tank: 220 L
    Diesel tank: 160 L
    Tailored fitted sheets for all 4 bunks
    Lazybag sunbrella (new Sep 2017)
    Sprayhood sunbrella (new Sep 2017)
    Bimini with rainwater collector sunbrella (new Sep 2017)
    Solar shower
    2 water Jerry cans (5 gallons/20 liters)
    1 Diesel Jerry can (5 gallons/20 liters)
    2 carframo scirocco fans (saloon and v-berth)
    WLAN router R36 and Tube-U long range antenna
    LED Lighting inside and for navigation lights
    •Dinghy and outboard
    Inflatable Avon Rover 2.81 Hypalon
    Outboard Suzuki 2.5hp four stroke (new 2014)
    Outboard Yamaha 8 hp two stroke
    •Spare Parts
    Oil filters, diesel filters, V-belts, impellers, shackles, pulleys, pods, cables, LEDs, propellers, motor oil, various paints and varnishes, Sikaflex, epoxy and glass fiber, O-rings, etc
    alaussa
    15.07.18 um 21:31
    Die Yacht liegt mittlerweile in Chaguaramas, Trinidad.
    alaussa
    23.09.18 um 23:43
    Das boot steht immer noch zur Verkauf. Ein aktuelles Video finden Sie hier: https://youtu.be/h-Q28bOFySo
    Und weitere Infos und Bilder, hier:
    https://www.sailboatlistings.com/view/71334
    www.instagram.com/alaussa
